Searay03
Have an '03 Searay w/4.3L mercruiser 18'6" bow rider, by the way I am a mechanical novice, still learning the ins and outs. WOT range is 4400-4800. In the past I have been running in the lower end of this range right around 48-50 mph (thinking of dropping to a smaller prop). Starting this season it is struggling to hit 4000-41000 RPM's at I think the fastest it has topped out at is about 45-46 MPH. Same prop (turbo 21 pitch) absolutely nothing has changed. Temp wise it runs just a bit above 170 deg. on the gage when warmed up. I took the dist. cap off and cleaned it as there was quite a bit of build up and also ran some sea foam through the engine trying to see if there was some build up I could release. Changed plugs, dist cap and rotor the summer before last. Cleaned flame arrestor 2 weeks ago, no luck... I do run 87 octane in it, unsure if a higher octane will help. My next effort is changing the fuel filter/water separator. At full throttle engine just simply sounds weak.
Any thoughts and opinions are appreciated.
