2003 2 stroke 90 fuel pump replacement
btucker805
Hi all, first time poster. I'm going to replace the fuel pump on my 2003 2 stroke 90 oil injection because it started spurting gas out the sides last time we took it out. Got the new pump kit and it looks like they redesigned it. Instead of having a hose connect directly from the oil pump to the fuel pump, there is a fuel hose with a Y that you run the oil line hose into. Other than that, it looks pretty straightforward. Has anyone done this job and have any tips? the Y hose isn't all that long, so I got a fuel hose connector and hose clamps to attach it to the current fuel lines. Also, the kit instructions say to use perfect seal, which I can't seem to find, but got Permatex aviation form a gasket instead. Is this the preferred substitute? Thanks a lot.
