can't get to my original post to reply, here's the problem. motor runs fine hooked up to the water hose, but put it in the water under a load hard to cranck and keep at idle, runs fine at high rpm. things I've done; comp. check 105 to 110 (was told this is good for a low comp. motor?) put in carb. kits looks like they needed it sound alittle better, still same problem. Mech. buddy told me to next check the stator, coil, power pack, and regulator. He also said to keep asking you guys questions. how and what order to I check these or should I be doing something else?
