2003 15 hp starving for fuel
briton
15hp starts and runs great the
15hp starts and runs great then dies. Fuel line bulb does not stay hard. Can pump fuel bulb and run for ever (until hand gives out). New fuel line (or find air leak) or possibly fuel pump?
I have checked the fuel line for leaks.
"In pumping the fuel primer bu
"In pumping the fuel primer bulb, you are acting as a manual fuel pump. This indicates a faulty fuel pump as you've eliminated the other possibilty (air/fuel leakage) that would cause a good operating fuel pump to draw air.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
"Thanks Joe, i will check the
"Thanks Joe, i will check the warranty first, then look into parts i may need.
I was operating in cold weather (20's), maybe there was iceing in the pump. will try to run in warmer weather. thanks again"
"To eliminate connector errors
"To eliminate connector errors (o-rings etc), attach the fuel line straight to the pump and test."
