Here is the condensed story:
A few days ago I went
to run my boat. Been in the barn for about 2 months.
Idled rough. When I gave
gas, would start to go, but then would not get up on plane-kind of bogged down.
Would not get up to speed. Would cut off at idle, but restarted fine.
Two days later, never left the dock. Idled ok, but as soon as I put it
in gear, would cut off. Never got good pressure in bulb.
Here is what I
did:
Replaced below deck fuel lines from bulb to pickup tube on tank.
Replaced bulb, anti-siphon valve, fuel pump, quick connect at cowling. Installed
brand new water-fuel separator. Removed Yamaha fuel filter and connected line
directly to new fuel pump (since I installed fuel-water
separator).
Primed fuel lines with bulb, ran great in driveway for about
10 seconds (I guess until fuel in bowls burned up) then died. Not wont stay
running.
Pulled ned fuel filter off and poured gas into glass jar twice
- no water.
Running out of ideas. If I disconnect fuel line on carb. side
of fuel pump, I have no problem squeezing bulb and have fuel shoot out of fuel
pump.
I don't think it's a carb. issue, since it runs when I take it all
apart and put,it back together and prime everything...
Today, I plan to
disconnect fuel line on carb side of fuel pump and turn it over to verify that
new fuel pump is working correctly.
Also thinking about sticking fuel
line fuel tank side of bulb into a gas can with new gas to see if it runs.
Any ideas? What am I missing?
Thank you so much.
Erik
Here is what I
did:
separator).
running.
- no water.
pump.
Today, I plan to
Thank you so much.
Erik
