Engine will pump water in ocean. With lower unit submersed above cavitation plate in tub (secondary water intake under cavitation plate) to flush salt water, engine will not pump water. Started engine in tub did not pump, Did damage occur to water pump? I have changed thermostat. tell tale hose is clear. Blew backward threw tell tale line bubbles in tub. Is air being induced above cavitation plate to keep from pumping? Any thoughts would help
