mdavis4750
The motor started running rough, at times it wouldn't idle and if it did when you would put it in gear it would die. When you start the motor it dumps fuel. Changed all plugs, checked injectors and compression is good. Changed the idle air intake control valve and now it won't even idle. Any ideas?
