I picked up an 11' Boston Whaler this past summer that had a 2002 Mercury 25hp 2 stroke with remote start/throttle. All was fine early on.
Then, without warning, suddenly the key start did not work. Not even turning over, zero, nada. Nothing trying to happen with key on. If I turn the key to the on position, I can pull start it and the engine has to be turned off via key. I checked the on engine fuse and it's fine. Plenty of battery volts. I pulled the neutral safety switch and went to far as to replace it (it was only $10 and seemed logical). Still nothing. I can't hear anything trying to happen when turning the key even jiggling the shifter.
At the risk of replacing the entire guts of the remote vs. purchasing one, is that worth it or what am I missing?
