Good day all,
Recently purchased this motor and installed on my boat.
Having issues to get it running, it cranks over, fires up and immediately stalls.
Following verified:
1. 40 PSI fuel pressure at the fuel rail holding for at least 10 sec.
2. When turn the key on I can hear fuel pump running
3. Have spark on all 3 cylinders
4. Have new fuel in the tank
5. Motor fires up and idles on any of the 2 cylinders, found out when checked for spark and removed spark plugs, once spark plug installed in the cylinder the motor will fire up and stall, spark plugs are wet with gas when removed.
6. Compression on all 3 cylinders is ~180 PSI
Your feedback much appreciated,
Following verified:
