Fly'n Family
Great forum, glad to have found it and all of the knowledgeable folks on it.
My question is on a boat I had surveyed that has twin 8.1L HO 425 hp Crusader motors with 330 hours on them, all fresh water.
Sea trial was on the Ohio river, where the water was pretty cold. Did a couple of WOT runs, and the engines never got above 145 degrees, and were putting out a LOT of steam. It was explained to me that, unlike my previous 454 Mercs, these motors are both closed cooled with anti-freeze, and raw water cooled on external engine aspects - and that there was no thru hull exhaust, all exhaust was ported thru the water outflow vents. That seemed pretty clear as when she was started, the different rumble and sound level was unmistakeable.
The volume of steam and the engine temps not going above 145 deg has me concerned. Should I be, or is this normal for this type of engine in a cold water environment? Not sure of the water temp, probably around 48-50 degrees, outside tem about the same - and humidity around 65%.
https://s26.postimg.org/4az762xjt/3870_Steam.jpg
