2002 50hp 3cyl
Frankrizzo
so I bouhlght this boat with a 50hp elpto merc. 3cyl 2002 model
It starts and runs pretty good but has a low speed stutter like just above idle. If I trim up motor so there is less load on it it does not sputter as bad .
Runs good at wot and mid throttle I put the idle mixture screws at factory settings. I was thinking about doing a line and sync and check timing
..."Runs goo I put the idle mixture screws at factory settings....."
Those are starting points only. You need to adjust for best idle (warmed up, in gear) and then ad 1/4 turn OUT.
Jeff
