My 2002? Yamaha 2 stroke 50 TLRA will not rev over 2800 rpm underload.
Problem occurred after 6 mo. Period of non use. Prior to running, I drained old treated fuelfrom tank and refilled with new 91 octane and topped off oil tank. Cranked up in driveway on hose, thenlaunched, warmed up and ran at 4400 rpms for approx 20 minutes. Returning to launch at 4400 rpm and openthrottle to 5200 for 30 seconds and engine lost power/dropped rpms to approx2800. Will only rev to 2800-3000 under load, but will rev higher in nuetral or reverse.
So far, I have conducted basic checks to include:
· Checked compression cold – 110 all cylinders;
· Installed new NGK plugs – some oil on old plugsbut not fouled;
· Checked fuel filter on engine – no water;
· Changed spin on water sep. canister filter;
· Checked/siphoned 6 gallon tank for water – no wateror trash;
· Ran in slip in forward – opened throttle butmotor only revs to 2800; even stopped and started disconnecting plugs and couldnot tell a bad plug/ignition coil;
· Check throttle linkage for full range of motionwith full throttle;
· Checked spark with inline spark checker-crankedand lighted bulb all 3 plugs.
I was relieved to see good compression, motor starts andrestarts quickly. Revs past 2800 in neutraland reverse.
I have not pulled carbs down since condition as filters wereclean but have cleaned carbs within last year. Also use non ethanol treated fuel. Any suggestions? I’m thinking abad coil not firing under load?
