J
Jeff Staples
Guest
" It won't run without hav
" It won't run without having the choke about 3/4 to 7/8 on. It will work at 90% performance if choke is left around the 3/4 setting at speed. It appears to be carburetion but I can't see any blockage.
Timing/spark and compression (112) all OK. I think a brass plug or jet might have fallen out of the carb. There are two open holes into the bowl and one open hole behind the choke flap, the other one is on the open face is plugged. This is like a low speed jetting problem but there doesn't seem to be a low speed jet. Any experience out there? "
