I'm getting very frustrated , I've thrown everything at this motor , carbs and jets cleaned set to factory specs,new fuel pump, new trigger, stator ,regulator , burned and bare wires replaced, and timed ...boat starts and idles, slightly rougher idle than I remember but will run up through rpms until you reach top then the rpms fluctuate between 4700-4100 ,high low, high low, then I bring the boat back to idle and try to run it back up in rpms again it will bog and not plane for a moment, if I bring the boat up to 4000 rpm and just cruise there, boat runs perfect, I've also replaced 2 out of 4 CDM modules , had spark and compression tested, good there... Any help wold be appriciated
