"I have a 2001 150 hp suzuki t
"I have a 2001 150 hp suzuki that has a shifting problem. When I try to shift into forward, it makes a grinding noise and will not go into forward gear. It will go into reverse with out any problems. I took off the shift cable were it connects to the shifting lever on the motor and tried to shift it manually it would not shift into forward. A short time ago I replaced the shift and throttle cables and was wondering if that might be the problem? If you have any ideas please let me know.
Thank you"
Thank you"
