2001 Ocean Pro 90 jerks ocassionally
Motor runs fine now. Been doin
Motor runs fine now. Been doing this since I put new prop in march. Could just be coincidence. Every so often the motor will jerk. Doesn't seem to matter the speed or trim level. Engine does not miss or rev. Wondering if could be the prop. Put original size on when replaced. Should there be any play on the prop shaft? There is about a 1/4 inch of play in it. Tilt and trim is fine.
"If the prop shaft has that mu
"If the prop shaft has that much end play, something is not right. It may not be the cause of your problem, but you should look into it."
"Thanks for the reply! When I
"Thanks for the reply! When I changed the prop, I am sure I put it on right but admit I did not torque it to the 55 lbs I have seen recommended. I will check this regardless and see if it makes a difference."
