2001 Mercruiser 5.7 EFI Code 34
jgren
So the starboard motor while underway last week decided it wanted to stall out above 1500rpm. This was after it was running fine above 3000rpm for twenty minutes. I did a compression test and got 195 across all eight holes plus or minus a couple pounds. The Distributor is new and the sensor inside is as well. The motor has new plugs and wires. I checked the code on the motor and got a 12 and 34. 12 was an indicator that the engine diagnostic is working and 34 is the MAP sensor is low. Should I be replacing the map sensor or where should I start looking?
