2001 JOHNSON OCEANPRO 115
C
Chris Mantz
Guest
" Started having problems rece
" Started having problems recently-engine would run fine, then, perioically, would loose power. (wouldnt get over 2000 RPMs) When I had a power loss it would drop RPS to 1800-2000 and once you got any higher than 2000 it would cavitate andsound bad and not push. Also wouldn't crank a couple of times; had to work the throttle under the cowling by hand while trying to start.
Replaced the plugs,cleaned carbs. Same thing still happed.
Mechanic thought powerpack was bad. Repalced pack. Ran fine, statrting issues went away. Ran yesterday and it ran good up till the end of day while running back in had power drop to 1800 then it starting "skipping"/ would jump from 1800 RPMS-5000 or so and back and fourth. Replaced flwheel sensor
Havent tested yet. Also replaced hand bulb on fuel line to make sure I wasn't loosing fuel pressure.... any one have any ideas??/ help !!!
thansk
CM "
