New to this site so thanks in advance to those willing to give advice! 2001 Johnson carb motor, had carbs rebuilt, chris Carson reeds, new ngk plugs, new plug wires, all new fuel lines and primer bulb, compression on all cylinders mid 90's which I know is a little low for this motor. Starts great, idles great, gets on plane great but when I get to high rpms it
will start to miss, kinda sounds like it's loading up, you can hear a big diffence in the sound of the motor, I can let off of the gas just a little and it will level out. It once I get back to high rpms again it will do it again, only does it around 52-5500rpms does this sound like cab flooding, or some time of electrical issue, could the carbs not be set right? Any help would be great l, again thanks
