EdwardHall
Hello,
My F80TLRZ 2001 Carb engine was set away while I was dying of lyme disease. After being finally diagnosed correctly and treated for 3 years, I am ready to get back out on the water. I drained the fuel tank, and removed and cleaned the carbs. I dipped them in solution after removing all the plastic components, and blew them out with an air compressor. I thought I did a good job checking to make sure they were clean, the main jets were horrible, and I cleaned them, and the idle passages on top of the carbs really well taking my time.
I did check and both fuel pumps are putting out at the pump.
Now both upper #1 Carbs are not getting fuel at all. You can remove the fuel bowl screws and there is no fuel in the bowls on both upper carbs.
I am at a complete mystery as why this is the case?
Could it be the old fuel lines inside the engine, but why would both upper carbs not be getting fuel?
Ed
Ed
