H
Harold Cazier
Guest
"Motor has been a problem sinc
"Motor has been a problem since new. Motor is used 8 to 10 time from May thru Oct. Trouble keeping it running.When problem occurs it just stops or will not start or if it does start it will not iddle or it will not run full out. Factory replaced carb at 2 years. Carb rebuild 30 days ago,(since ran gas from carb after use) ran Ok but not full out 2x last 3 weeks, then yesterday it starts and dies. Today it started after a lot of fiddling with choke. Got it running ran for 30 min. ok. Motor is totally unreliable. Dealer just says it the old gas after he has worked on it one to two times per year. How have others lived successfully with these problems?? Suggestions?? Does any motor manufacture make a small motor than runs on todays fuel. I'm ready to lose this one."
