2001 DT225HP EFI
gradyman
"Perplexing problem - at any R
"Perplexing problem - at any RPM, my engine will loose 100 or so RPM's for just a second or so. It never seems to want to quit and returns back to the original RPM. It will happen every couple of minutes or so. Have had compression, spark, etc checked out by a non-Suzuki mechanic - everything checked out fine."
"I thought of that. The first
"I thought of that. The first thing I did before getting a mechanic out was to change the fuel filter. Didn't look like there was any water in it. I topped off the tank and put some "Sea Soap" treatment in it. Man, this is frustrating. Do you know if this engine has a computer port?"
we you need to do a pressure c
we you need to do a pressure check on the fuel system
you have a vst tank also
and 2 other efi filters
