I have a pair of 2001 Crusader, Captains Choice 5.7 MPI engines. The port one starts fine, but the STBD one takes excessive cranking. I have to adjust the throttle, and do all sorts of stuff to finally get it to start. Sometimes it's starts right away, other times it can take several minutes. I've replaced the low pressure, high pressure fuel pumps, the FCC filter, fuel/water separator, distributor cap, rotor, and coil. Any ideas what else it could be? Once it's running, it runs fine. Could the timing be off? When I go to time these engines, what should I set it at? Retarded, or advanced and what degree? Thanks for all the help. If I use starting fluid, it starts right up. I don't do it often, just a test.
