Had a dead battery a couple days after last use.... Charged up and hear the fuel/vapor pump on when switch is off. Unplug the pump and are receiving a constant 12+volts at the plug. In addition to all of that I hear the main relay in the front of the motor click very slightly when I turn the battery on and the motor will not start.
What at do I have? A bad main relay? Why would constant voltage be there with the key switch off? Key switch bad?
Stuck a screw driver in the plug wire and looked for a spark jump to ground. Does not appear to be firing.
thanks
thanks
