Nightwings
I had the power head off last Friday replacing the power head to mid unit gasket, got everything back together for trip to the lake Saturday all was good till I went to throttle up. Engine acted like it was skipping then cut off. Put shifter in neutral restarted engine when I went to put it in forward the shifter was tight. When I got to the house I checked shift rod offset it is pointed to front with rod disconnect shifter is nice and smooth like it always has been. I pulled LU off to check to rod for bends no bends. If I spin the prop as I push or pull the rod it does fine most of the time every now and then it will not engage at first and I have to release and pull or push it again before it engages. I believe that is causing my tight shift. Any ideas would be greatly appreciated.
