2001 75hp mercury
timato
"My problem is that i can,t ke
"My problem is that i can,t keep the motor runnig. the only way ican keep it running is to keep pressing the choke button . I have replaced the plugs rebuilt the fuel pump And changed the fuel hose thanks in advance."
"Yep, carbs are clogged - &#34
"Yep, carbs are clogged - "prime to run" indicates that the low speed (idle) jets are clogged - which means there are other clogs lurking.
Pull the carbs, disassemble and clean - if the needle valves look even slightly distorted, get a carb kit - in any event replace the gaskets..."
I have general knowledge engin
I have general knowledge engines but i have never worked on carb is this a diffulcult job. or woud i be better off taking it to a shop
its fairly easy but if u dont
its fairly easy but if u dont have any experience you should take it in. but its easy jus look at every part befor u take it apart
