So, when you first crank the motor and then intermittly afterwards, I lose power to the top cylinder. Have moved the coil packs around to see if one was bad, have moved plug wires with the same thought. Haven't changed spark plugs yet, but I guess they could be it too. Its always the top, even when moving the above around. When it loses power, I pull the plug wire and nothing happens. If I pull any of the other ones, the motor dies.
Problem comes and goes, almost always at first.
Either way, what should I check next? What's next in line after the coil pack?
Thanks, B
Thanks, B
