kimbroughblake
I’m having an issue with the fuel pump relay burning up on my carbureted 5.0. Put a new relay in, will run about 30 minutes and stall. I have to put a jumper across pin 87-30 which closes the switch and allows the fuel pump to run when relay is landed in base. Issue is, fuel pump runs all the time when battery is connected. Remove jumper and fuel pump won’t run at all when alternator is turning. Anyone ever had this issue before?
Thanks, Blake
Thanks, Blake
