"[b]"The reason i ask is w
""The reason i ask is when I winterized my boat most of the antifreeze was coming out the two openings in the lower transom and only a little on the prop??? "
Ayuh,....
My WAGuess is,...
It's been run without water at some point,..
The Exhaust Flapper Valve burnt up,+ part or all of it is lodged in the lower exhaust cavity of the gimbel housing,...
Just a WAGuess though...
You should drain the motor,..
Then run the antifreeze, if that's what you want to do....
I drain My driveline Dry,...
And store with the drive Down, or removed....
In your case,.. I'd drain it....
Air just Don't Freeze..."
