Working on a friends boat, engine is a carbureted 150hp, saltwater ed. Motor has sat for over a year. Here is the problem: I have cleaned all of the carbs including the needle and seat, and all appear to be closing properly when the float bowls fill. When i start the engine, it will run and idle well for a few moments but then fuel will literally pour out of lower 2 carbs. Note that while the boat is on the trailer, the engine is trimmed up probably 15 degrees or so; I suspect carbs may be working ok, and the angle the engine is running at is causing the fuel to leak from the carbs. My friend who owns the boat claims that angle is reasonable for it to run at and is not the source of the prob. Before we spend any more money on parts, i would really appreciate some input on what the problem and solution may in fact be. Thanks a ton in advance!
