2001 150 xr6 choking out at start
mastersjosh
2001 150 xr6
motor will crank then choke down and almost as if flooding out. after 5 or 6 times of cranking then choking out it will run and idle fine. when i try to get on plane somtimes it will bog then jump right out...it sure does seem the motor burns alot of oil/smokes bad...plugs arent fouling/compresion is good...is there a way to check how much oil the VRO??? is sending to motor or what?
A factory service manual has the details to check oil pump output.-------------On cold start you have to operate enricher till it warms up.
