2001 115hp OceanPro shift rod height linkage
ccmello
"I recently removed, disassemb
"I recently removed, disassembled, and reassembled my lower unit because I had contaminated gear oil. I'm having trouble getting the shift rod back to the correct height. The Seloc manual says either 26 1/4 or 26 3/4. Tried both because the book wasn't clear on which model. Right now, everything operates but i can't shift out of forward. Is there something special I need to do to realign the shift rod with the linkage?"
Shift Rod Heights for 20"
Shift Rod Heights for 20" OMC-Bambardier Outboards*
CYL YEAR HEIGHT
2 1976-1988 20-29/32"
2 1989-UP 21-15/16"
3 1978-UP 21-23/32"
V4 C/F 1978-UP 21-27/32"
V4 Looper-Small 1986-1992 21-15/16"
V4 Looper-Big 1993-2001 21-15/16"
V4 60° Carb 1995-2003 21-1/4"
V6 C/F 1979-1991 22-1/16"
V6 Looper 1986-2003 21-15/16"
V6 60° 1991-2003 21-1/4"
V6 60° - F.I. 1998-2003 21-3/4"
*Add or subtract 5" for your application
"thanks, i'll try 26 15/16
"thanks, i'll try 26 15/16...does anyone know if there's a trick to re-seating the shift rod in the linkage? or does it just happen when you line things up right?"
"usually,we split the pans,..r
"usually,we split the pans,..remove air silencer(cover)..to access.disc of shift cable is necc."
