"After a normal day on the wat
"After a normal day on the water headed for the dock,as usual I run at full throttle for a short run. Upon reaching the No-Wake buoy I dropped the throttle back and alarm sounded, first time ever. I shutdown engine, checked oil was ok and temp.appeared normal. Turned the key to restart alarm still sounding? Trailered without engine and went home. according to manual I have good water flow coming out the water pump indicator hole, alarm still sounds when you turn the key on a cold engine. Engine has always ran fine and never given trouble, I would like to assume its a sensor or filter issue but definitely not a marine engine tech. Any help appreciated, 2000 MODEL, 40HP MERC. S/N OG991437
Thanks, Terry"
Thanks, Terry"
