I have a mercury 2 stroke 100hp 4 cylinder efi it works flawlessly once started and heated...
but when i turn the engine off, and try to re-start the starter would like hold it self from spinning and the battery goes down lower then 9v.. and sometimes it just fires right up. now i know for sure the battery is good as i tested it with a battery tester on load with 680a test... what could be the problem? please help!
also i have noticed that in between 2000rpm and 2500rpm the engine vibrates a lot seaming it would like to stall but doesnt, never stalled....
further more the engine in neutral sometimes stalls. and that in-water idle rpm is approx 1000rpm and on the muffs (hose) it idles at about 2000rpm and i ask myself why?????
this is my first boat, compression was 7 bar on each cylinder... and it has new spark plugs, also ran an engine cleaner with fuel.
and it has new petrol... it is also a very thirsty motor... please help me... thanks
