"The engine starts just fine,
"The engine starts just fine, but when I open up the throttle it bogs down like its running out of gas. I,ve had it to the machanic it show no faults codes on the computer. Every once in a while it will run just fine but when I shut it down and restart it will do it again. One suspect part was the needle valve in the fuel pump, it was replaced but the problem still happens. It will run fine at higher rpms in neutral but not in gear in water"
