Someone please help. I removed my lower unit to replace the Impeller. Everything went well till I went to replace it. The gears are not working properly and won’t shift. When I removed it it was in neutral. When I was reinstalling it, it wasn’t going on so I turned the flywheel and it worked. Since it seemed to be stuck In gear I removed it again to try and figure it out but no luck. While trying to figure it out I turned the gear shaft that is on the lower unit to see if that did anything but nothing. Hope I didn’t make this more complicated. Thanks in advance.
