slimfishin
I have a 2000 johnson 50hp that I assumed had a carb issue so I rebuilt them like I have done in the past but no luck. Carbs seem spotless. Everything works perfect up to about 2500rpm then boggs down. Disconnected heat sensor and still same problem, fresh fuel and water pump. I thought "slow mode" from what I've read online, however if I choke the top carb with my hand it'll rev up over 2500 but drops strait back down when removed. This only happen when in water and in gear. Any help is appreciated, this motor has been used and abused but well maintained if that makes sense.
