"i have a 2000 javlin with a J
"i have a 2000 javlin with a Johnson 115 that is missing when i go more than a 1/4 of throttle to wide open and at times while it is missing i will feel like a cylinder starts firing and the boat will go on up on plane, one time it ran good all day for about 5 hours then started missing again.i removed fuel filter it was clean. i have removed all the carbs to see if they had trash in them, found nothing. have checked spark from all 4 cylinders with a spark tester and they all fired. replaced spark plugs and have had no luck. noticed that the fuel bulb does not stay hard! not sure if it should or not on this model. also was wondering if the power pack could cause a miss or if it would not even run. please help!"
