OysterMan2018
Starts fine. idles for a few seconds then ramps up. Not really sure how else to explain it.
It's in neutral; the prop isn't spinning. and it just starts to ramp up and would probably explode if i didn't kill the motor.
I've ordered and received a new ignition switch (but not sure how to wire it). The one i have now is old and the spring doesn't work, so the starter will stay engaged if i don't manually click it back one. Also, there is only two wires connected to the old ignition (although it has three leads) and the replacement (which has a push to choke action) has six wires coming out of the back.
Any help would be great.
