newboater67
I recently installed a new tach and charging coil. I ran the motor for about an hour just fine. Coming back in it started sounding like it was missing and sputtering or coughing at low rpms. It idles high, around 1100-1300 rpm which I verified with an inductive timing light on all 3 cylinders. It coughs thru carb #3. I pulled the plugs and it's fouling plug 3. Looks black but feels more like gas than oil. I checked the timing marks and they are right on, but when I look into the cylinder bore with a fiber optic inspection camera and bring cylinder 1 to its absolute highest point, I'm 3 teeth past the timing mark on the flywheel. Am I being too critical since I can actually see the piston? I'm thinking the timing is right. The flywheel is pinned so there is no way to move the flywheel 3 teeth. TDC for cylinder 1 will always be at the same point on the flywheel. I checked the compression and got 184-184-186. The Honda service manual calls for a minimum of 199 but I'm hoping 184 is good for a 13 year old 4-stroke. Leak down results were 2.5%, 5% and 5% at TDC with an OTC leak tester. Carb sync looked balanced but I didn't right down the numbers. I haven't messed with any carb adjustments yet. I've had the boat a year and also recently switched from E10 to REC90 non-ethanol gas. I drained the tank down, and changed all the gas lines, filters and plugs when I switched gas. I did not change the fuel line/primer bulb. I removed the muffler and feel gum buildup on the bottom near carb 3. Should I leave the timing alone and tear down and clean the carbs before doing anything else?
