midaoutlaw
"Bought this motor from a frie
"Bought this motor from a friend. The motor has not been in the water for the past year. It ran fine before being put away. Don't know if the fuel was run out before storage, but my friend thiks he did run it dry. Before launching this past weekend, I changed the fuel lines, water separator, plugs, oil and gear lube. The motor started fine. When put in forward gear and under load, the motor bogged down. I could get maybe 3k rpm max. When in neutral:shifting from zero to full throttle, the motor will scream to 6k rpms. When bogged down under full load, full throttle, I can pull the manual choke out partially while underway and get to 5500rpm and run beautifully. Push the choke back in and I slow immediately back to 3k rpm. What should be my next step(s) to sort this out? Thanks! Todd"
