Daniel Thompson
MY 2000 15 HP honda outboard had no spark. I cleaned the carb & fuel filter check the gas lines and fuel pump.
I replaced the pulser coil, replaced the regulator, installed the high output charging coil. BZought a new Ign coil
the motor now starts but runs poorly and stalls. I reversed the spark plug wires and it runs poorly and then stalls with no differance which way i have the spark plug wires. The two ign coils test about the same Old and new but neither test within the results per the book. Primary tabs old >9 ohms New 1 ohm supposed the test at 8.01 to 9.79 ohms. Secondary old 29.4 on the 200 k scale new 27.8 on the same scale supposed to be 8.01-9.79 ohms
the only thing i have not replaced is the exciter coil and the control unit module?? I really don't know why it does not make a differance when i switch spark plug wires?? Clovis CA Help Please?
