i have been getting a check engine alarm that turned out to be the emm overheating. i had the mechanic give a quick look at the lines and he said it wasn't right and that the hose should go straight from nipple on top of block to emm. it previously wasn't. i've been looking for schematics and pics to figure out where all the lines go but can't find anything that shows where they go. can someone please explain where all the hoses go or send some pics from either side and back. my specific issues now are the nipple on port side back towards tell tale that actually supplies water, where does it go?(mine went to outlet of vap separator which i'm told is def wrong). wehre does outlet of vap sep go?(i'm told should dump into motor leg somewhere). and there's a port on storboard side towards front that was connected to adapter and then to nipple on block and top of emm, but that line just dumps into leg.(if emm goes straight to block, wher'es this port go?)
and not sure if it matters but it looks like theres plugs in some ports. so maybe someone moved em around which is y it isn't looking normal. i dunno. i'm at a loss. hopefully someone with the same engine can shed some light or better yet post up some pics.
thanks.
thanks.
