i have had this problem for years. have discussed it here but long ago. motor starts on one pull idles all day, will run wide open for maybe 10 minutes or until i slow down then it dies and will not fire until it has cooled (15 minutes or more) does the same thing over again. temp is good. i changed the ignition coil (70$ wasted). now i am curious the oil sensor or switch might be opening when it gets hot. how do i bypass this switch to try this out? it has one wire on it. i disconnected it - no spark, then grounded it - no spark. any other suggestions welcomed. Outboard mechanics don't help because this cannot be repeated in a tub.
