darlington_john
First day out in sub-zero temps and the*Honda was a pig to start as usual but that is another thread in itself.
Engine*was running fine all day long and when I went to put the boat on the trailer, I trimmed it up and that was it for the trim function that day.* Trimmed it just enough to be able to make it home without any issues and I removed the fuse/wire connection black cover to make sure that all my contacts were fine and they were but there was no movement/noise from the throttle cable trim, engine trim, or bow trim controls.*
Drove 1.5 hrs home and let the boat sit for another hour in the driveway before I made it back outside for more trouble shooting and I hit the throttle trim control and it began to work again.* Moved to the motor control and moved it up and down a few times and then it froze up again.* I knew it wasn't the battery as the motor worked fine and was running fine but the trim didn't function when I was on the water so I left it for another 15 minutes and it worked again.* The motor did seem to whine*a bit when it was in the trim function, especially before the tilt kicked in so*I thought it may be low on fluid.* Mind you the temps were also above freezing when all of this was going on.
I put the motor to the top position and removed the cap screw on top of the reservoir and I didn't get the screw off before oil started to seep out so I would assume that there is sufficient fluid present.* It seems to work now but the last thing I want to do is head back out to the water and find the same thing happening again.
I'm thinking that it is either related to the solenoid (funny that both would go at the same time as I thought there was one for upward movement and one for downward movement) or the motor is on its way out.* Boat has never seen any saltwater and there are no signs of any leaks present in the tilt/trim/reservoir.
Any thoughts????
Any thoughts????
