2000 90 yamaha power trim
joepxt
"Hi there replaced a seal on o
"Hi there replaced a seal on one of the hydraulic rams on the weekend topped up the fluid level bleed it using the bleed screw and took the boat out afterwards, trim was working but half way thru the day was making plenty of noise when tilting up and down but wasnt doing anything, i bleed it again while out there and a lot of air came out then was mint as,now when cleaning it on the driveway trim wont go all the way up bout 3 quarter the way but will go down any ideas would be great thanks joe..."
you need to bleed it more
h
how i do it is ez
trim motor up
add fluid
then use manual relief valve to drop motor
wait 2 mins then trim it up
check fluid
repeat 3 times
