I have a 2000 Johnson 70 hp that wont start. I turn the battery on, the ignition beeps and all instruments work. When I turn the key, it kills all the power to the boat and nothing works. I have to turn the battery off then on again to get power back to the console. It is a new fully charged Battery and I have even tried it while being jumped to the truck. I thought the ignition may have had a short so I replaced it. No change. I can jump power from the solenoid to the starter and have power if I do not turn the key all the way. I f I try starting it with the key, all power is cut to the motor until I turn the battery off then on again. Any suggestions? Thank you in advance!
