killerbe20
Hey Guys,
I have found an oil leak in the oil pressure alarm switch on my 2000 7.4L MPI. The leak appeared to be where the stud/nut enters the switch. I tried to tighten the nut/stud and have made the leak much worse. This can be seen in the first picture.
When looking up the part number, I found a much different looking switch which can be seen in the second picture.
my first question is whether the switch I have found will work as a replacement. I am thinking they changed the design so the same problem does not happen again. my second question about changing it out. Is it a simple unscrew the old switch and screw in the new one or should I be expecting much more? Should I be expecting to dump a bunch of oil when I remove the old switch?
thanks!
Josh
thanks!
Josh
