Hi. New to this forum but have researched here before many times. Sorry for the long post but trying to include all info.
Have an engine that has a bog spot starting around 3k and clears up around 4k.(easy or full throttle) New engine to me so no history and has ran like this from the start for me. Cranks and idles perfect, full throttle, pass the bog, runs great. only issue is from 3-4k
Cleaned carbs that were not dirty or clogged. Floats around 12-13mm on tapered end/edge of float
Comp. is 121-122 on all 3. verified spark w/ timing light on all 3 going down the river during the bad spot.
Did apply push key choke during bog w/ no change except if held long enough motor will die off of course.
Also pumped primer bulb while bogging w/ no change.
I did find that when I disconnect the fuel line from engine it does not bog. Runs great all throttle ranges untill it starts to run out of fuel. I suspect it is over fueling somehow.
Has the carbs that have the little round gasket on top of the main fuel tower. Only has the one main jet that I can tell. Issue is just like a too rich mid range jet in a bike.( I work on Harleys)
Any help or ideas? Any things to try or check next please.I guess it has to be the needle and seat somehow right?? thanks!
