Hi guys
today I went out and the motor worked fine and all of a sudden it wouldnt tilt down or up. then it started tilting up but wouldnt go down. I made it back to boat ramp and when boat was on trailer the motor went down then wouldnt come up.
there was a clicking in the relay at front of engine under the cowl. like the relay was stuffed or battery was flat (which it wasnt as motor started fine etc).
I have removed this relay and stupid me tried to open it up as the top is screwed down but 2 wires on each end go through the top and join the windings, which broke.
I know I will have to get another relay but can anyone tell me if this would of been the cause of the problem as when I pressed either tilt up/down button on motor or throttle control there was just clicking which I could also feel when I placed finger on the relay.
I was thinking after I stuffed this relay that it may of been another problem that was causing the relay to click????? the relay is under cowl in engine not on the tilt/trim motor.
thank you
thank you
